Not working no power
How do I get my Wd external hard drive working again there's a rattling inside like somethings broke but it worked before what can I do as all my family photos are on it....please help
좋은 질문 입니까?
좋은 질문 입니까?
No it does not sound right. Post a couple of photos. All you may need is an SATA to USB adapter like this: http://www.walmart.com/ip/35118076?wmlsp...
or an external enclosure.
해당 답변은 도움이 되었습니까?
Most USB external drives these days have the SATA to USB conversion integrated in the drive, which means that you can't access the SATA channel. That is, you could, but it requires some fiddling. Basically you'd have to figure out the internal SATA channel, detach it from the USB converter, wire it to a SATA connector, and add a power connection to the drive.
@flyingdutchman - most of the drives I see do have an adapter but they are usually removable. He needs to open it if it has not been, and post a couple of photos so we can see what it is and give him the correct answer.
Oh I see what is going on. It's probably cheaper to buy Sata to USB adapter or another external hard drive enclosure than repairing the USB port for the external hard drive enclosure.
@benjamen50 Sure the adapter is $13.00. You don't know if the current enclosure is good or if it's the hard drive. The adapter is the way to go. Then you about both and know which one is usable for cheap.
You can take the hard drive out of its enclosure and connect it to a desktop computer if you have one. Otherwise you can take it to a computer repair shop that can recover the data from it or repair it if it's physical damage on the USB port of the hard drive enclosure.
해당 답변은 도움이 되었습니까?
Hi thanks for an answer for this question. Ive took it to a local computer shop who say that its probably the pins on the connection and will charge around 50 to 60 pounds to have it repaired , does this sound right
Ive been told by a computer repair shop its the usb in the hard drive that's gone a pin has broke but he cant fix it what can I do from now as WD say they will charge £300+ just to look at it ...please help as wife really upset if lost all birth photos of our kids. thanks again
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 9
30일 전: 36
전체 시간: 5,590
