Ethernet cable (as well as board) not detected
After a power on of the iMac, my ethernet connection was no longer working.
Checking the "Network" preference pane shows "Ethernet cable not connected" - though it clear is. I tried several other cables - no luck. I don't have another computer to do more tests.
Checking the "System information" in the Ethernet tab shows "No ethernet board".
Is there a way to confirm the ethernet board is dead and then repair it ?
Is there a way to "restart" the board (I switched off/on several times already) if it's not dead ?
Thanks
좋은 질문 입니까?
댓글 3개
can you try resting the pram and smc
Alex Hus 의
Thanks for the suggestion. As a matter of fact, I did reset the SMC (without knowing it) because it only needs to unplug the power cable and wait for a few seconds, which I did during my various tests.
Resetting the PRAM doesn't seem possible, as it needs holding some keys on the keyboard during startup, and I only have the bluetooth keyboard.
stefmillet 의
My problem is that I continue to lose my connection to the web with both the ethernet and wifi. The only way to get it back is too reboot. After a while the connection will go away again. Lose both wifi and ethernet. Changed the ethernet cable, no change.
Leonard Jessup 의
