Bleach dispenser fills with water.
After each wash, bleach dispenser is full of water. I don't add bleach with each wash, but water is always in the dispenser.
좋은 질문입니까?
좋은 질문입니까?
The dispenser for the bleach is clogged up. It is a siphon dispenser and if something gets in the tube it will stop siphoning. You can pull the complete tray out of the washer and take it to a sink. There will be round circular siphon towers there and you will need to clean them and under the trays there are also the same towers and clean those. Reassemble and holding the complete tray as level as you can slowly run water into the bleach dispenser cup until it starts siphoning out. If you stop the water it will almost completely empty the tray. Leaving very small amounts of water is normal.
The venturi works by creating a siphon as the water runs past. It it difficult to see a problem but very slight changes or sediment build up can change how it works. As the water runs through the venturi it should draw the bleach out of the container. If water is spraying in instead of siphoning out then the venturi is usually the cause of the problem.
Clorox also wants this to work for you and here is information from them: https://www.clorox.com/dr-laundry/issues...
이 답변이 도움이 되었나요?
"You can pull the complete tray out of the washer and ...."
Is this accomplished by simply opening the top-load -lid of the washer and carefully prying the (plastic?) cup out of the top of the washer?
Thank you! This helped immensely
mine is a front load washer. The Bleach dispenses fine, but when I wash clothes with or without bleach the Bleach dispenser is standing in water some of the time when load is finished.
지난 24시간: 2
지난 7일: 10
지난 30일: 27
전체 시간: 19,717
댓글 1개
My washer and dryer are new. My family has used Maytag appliances for over 60 years. I hate this machine. You almost fall in top load washer to get your clothes out. Half the time my dark clothes has residue on them. I would give this machine 1 star out of ten
Jeanette Young 의
