주요 콘텐츠로 건너뛰기
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
Mic Works, then stops working, then works again, on and off.
This has been ticking me off, as of Late, I got an X12 for my PC for a great headset to use. However the mic at times work,s then stops working without anything being touched. The cord is plugged in all the way and it cuts in and out apparently, from what a friend tells me.
I use Skype to talk to a friend when we game. So, It worked a bit fine before, but to get the headset working I need to fiddle with the mic In cord by plugging it halfway in or what not.
I don't think This is supposed to happen.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
I assume that you are using this configuration.
It could be that connecting springs in the Microphone socket of the PC have lost tension and therefore are not making good contact with the plug.
It could also be that the wiring in the microphone plug itself is loose.
Try the following: While speaking to someone over the microphone, firmly hold the microphone plug when it is in the socket and gently flex the cable at the rear of the microphone plug. If the 'voice' is lost it may be that a wire is loose in the plug. (or that you are not holding it in firmly enough). If the 'voice' is not lost it probably is the socket that is faulty.
As it is a new headset, I'm assuming that the microphone plug itself, which is connected to the headset cable is OK as over time these can wear, by being inserted and removed often over a period of time, and cause a similar problem.
Not knowing what type of PC you have means that I can only give a general answer as how to fix the problem.
A lot of PC's/laptops have the microphone socket mounted on the motherboard and therefore it is difficult to repair them. If you are fortunate, especially if you have a PC, and the microphone socket is connected to the motherboard via a cable connection then you may be able to buy a complete 'panel' with microphone/headphone/USB socket which you can install in the case and just transfer the connections. In the case of laptops sometimes the mic/headphone sockets are also connected to the motherboard via cable and the socket 'board' is actually a replaceable part.
Hopefully this is of some help
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
typh39 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 9
전체 시간: 6,715
