주요 콘텐츠로 건너뛰기
Power Mac G5 Late 2005는 10월에 소개되었으며 다음 해 8월에 단종되었습니다. 2.0 GHz 듀얼 코어 프로세서, 2.3 GHz 듀얼 코어 모델 번호 A1177, 그리고 2.5 GHz의 듀얼 코어 듀얼 프로세서 (쿼드 코어)의 세 가지 구성 옵션이 있습니다.
26 질문 전체 보기
Is it possible to upgrade a PowerMAc to the newer Intel Processors?
I have a good Power Mac G5 Quad that I'm happy with. But it seems every software now needs the INTEL Mac. Can I upgrade the old system instead of buying a whole new one?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
Sadly, no.
PPC and Intel are not at all interchangeable. The closest you could manage would be gut the case and make a hackintosh, by finding an intel logic board that would fit inside (may not even be possible).
My advice is to keep using the old software as long as you can. Look for backward compatible versions of newer software.
You should look for a good deal on an Intel Mac you can max out the ram on (should be cheaper than getting a new box). Also upgrading CPUs are not simple DIY tasks, lots of dismantling of the machine involved, and limits as to what OS runs on what board/processor.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
해당 답변은 도움이 되었습니까?
점수 6
2 댓글:
+ agreed
Apple and upgrades don't generally fit in the same sentence together, regardless of the device. Good advice, machead3. +
댓글 달기
No. You'd have to rip out the entire logic board / "motherboard".
It makes a beautiful (yet expensive) doorstop.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Derrick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 6,925
