주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
Water Damage - diagnose SSD or Logic Board fault
I've been given a Macbook Pro 13" Retina that had water damage (something, not sure what, was spilt on the keyboard). It was about a year ago, and everything is working but the SSD - I'm just running everything off an external drive for now. The disk (physical disk, not drive) doesn't even appear in disk utility or in system profiler - I can't find any reference to it.
Does anyone know how to isolate whether it's the SSD or the SSD connector on the logic board that's at fault? Which is more probable? I'm guessing just finding another, known working SSD and trying it in there would be the easiest, but it'd be great if there were a quicker / potentially cheaper way.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
You can do a physical inspection with a magnifying glass looking for any of color spots or corroded areas on the logic board . Check the connector for corrosion and simply cleaning the contact points between the SSD and the connector could do wonders. However if the SSD was shorted out it could be fried and the only way to tell is to actually replace the drive. When you do replace the drive clean the connector to make sure you don't just short it out again if the contacts are corroded . Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
Distilled water or isopropal alcohol 95% or better for cleaning never use straight water
did you ever figure out the problem? i'm having the same issue
댓글 달기
귀하의 답변을 추가하세요
Bede 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,039
