주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
DEAD Samsung Galaxy S5 Need HELP
Hi Everyone
I've recently been given a Samsung s5 from my mother in law which hasn't been charged in a good few months as she didn't use it so i bought a new charger for it but for some reason it doesn't come at all or show any signs of it even charging phone does work fine tho all that happened was it was put away without it been turn off that's all
Just need some help fixing this problem please
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Have you left it on charge for some time with multiple chargers and still not getting any sign of life?
If so I would inspect he charging port ad make sure it is not damaged. If you know anyone else with the same phone see if you can borrow their battery and see if it comes on. The LCD could also be damaged which is why you don't see anything on the screen even though it is charging.
i'll try leaving it a bit long then i have :( and have a look at a new battery
thanks
댓글 달기
답변 1개
가장 유용한 답변
Hi Tom
Try new battery, if you have another phone charge the battery first and then put it in the phone and see if it is going to switch on.
Hope this help
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
yeah wish i could try that don't have another phone unfortunately but i'll be have a look at a new battery tho
thanks
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 601
