주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
iPhone 5s Battery drains fast, motherboard issue
I have an iphone 5S with battery problems, the battery drains fast even if the phone is in rest mode. Ι changed battery but does not seem to work so i think that the problem is in other part of the phone, then i tried to test all the phone parts, i removed the charging port, removed the lcd and and i left the phone for some hours and i saw that in this case the battery drains fast two. About 10% in an hour. I think the problem is in the motherboard, i would appreciate if someone could help me how to check the motherboard and what to do. Thank you so much
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Do you have an external DC PSU that you can power the phone from? If you do you can measure the current draw of the phone.
Also, if you have a Mac, search for a program called "coconut battery" it will help you diagnose whether your battery is in need of replacing.
I have also found that more often than not, when you replace a battery on a 5S, you also have to restore the phone - and no back-ups allowed.
Those are some things to consider before you just dive into the motherboard
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I replaced the U2 ic, i was very carefull i thought i made good job but after this iphone stuck to apple logo. But iam sure i made great job, no other capacitor removed near U2 ic and i lined the chip perfect. Maybe the chip i bought is low quality and does not work. Do you know any site to buy high quality chip?
itunes does not regognize the phone any more
Also for info the windows version is pretty much called 3UTools.
@benjamen50 I'm starting to think you have stock in 3uTools ;>).
Kidding or course...I tried so many different tools but I agree that 3uTools is the best.
댓글 달기
귀하의 답변을 추가하세요
johnfl21 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 871
