주요 콘텐츠로 건너뛰기
This iteration of Amazon's Kindle Paperwhite series was released on June 30, 2015. The Kindle Paperwhite 3rd Generation is a 6-inch, 300 PPI reading display tablet that is Wi-Fi capable. The designated model number is DP75SDI.
48 질문 전체 보기
Why does my screen get stuck on a page when I’m reading?
I’m having trouble with my Kindle sometimes when I turn the page. The problem is that when I try to turn the page, the page won’t change, and I’ll try again a few times and it will either take a few minutes just to simply turn the page, or it will freeze completely and I’ll have to refresh my Kindle in the middle of my reading. Is there any way to fix this, or is my Kindle just slow?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
My kindle fire is frozen. I am unable to get to home page nor settings. I have tried to turn it off and that doesn’t work either. Any suggestions?
댓글 달기
답변 1개
가장 유용한 답변
Hi Delroy! Don’t worry, that’s a very common problem with Kindles, and the solution is relatively simple. What you need to do is go to settings and turn the page refresh on. This makes it so that the screen refreshes every time you turn the page, which should solve the problem. So first, hit the settings button on the top right of the screen, then go the reading options, and finally turn the page refresh on. Also, to simply improve overall speed, it might be a good idea to delete some unnecessary data that’s stored on the device, but the page refresh should work. Hope this helps!
해당 답변은 도움이 되었습니까?
점수 6
댓글 2개:
My kindle wouldnt turn page i followed the 40 sec hold button in it rebootedby the screen niw frozen on home page, i e ffollowed e erything including putting it on charge its now fully charged but still stuck on home page, settings back store on top of screen nothing works
I have a brand new Paperwhite and I notice that when I’m reading outside in the bright sun, page turning is somewhat problematic. (Behavior similar to that described by Delroy Fong.) I will try the page refresh tip and see if that helps.
댓글 달기
귀하의 답변을 추가하세요
Delroy Fong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 13
7일 전: 117
30일 전: 579
전체 시간: 27,268
