주요 콘텐츠로 건너뛰기
Mac Pro First Generation는 Apple Inc.이 제조한 Intel Xeon-기반 워크 스테이션 컴퓨터입니다. 2006년부터 2008년까지의 컴퓨터가 1 세대 모델에 포함됩니다.
312 질문 전체 보기
installing new video card
I installed the ATIRadeon x1900 card (512MB) in my 2006 Mac Pro. Can't change resolution- its at 1200x800 on my 30 in cinema monitor and there is a warning that my video cable needs to be plugged in. There is no video cable, the card just plugs in.
Any ideas? I did zap the pram.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
The video cable runs from the card to the monitor. Switch ports
It's pretty important to get all the ati software installed so, the fan controls on the card work properly. On some machines if you have had no extensions and stuff for ATI in there before, the card may have some odd behavior until you get the software installed. If your old card is still working it may make sense to install all the ATI Utilities, THEN swap the cards, bootup, and run the cache cleaner (as mentioned above for nVidia cards, and in the ATI Readme) to make the system load the
The ATI cards don't have an alarm on them like the nVidia cards, If you don't hook up the power you simply get no video, (no annoying alarm, just a black screen). If there's a power problem and you have an ATI card, hints indicating poor power will be things like the card running hot, strange freezes or other behaviors as mentioned above for the nVidia cards. If the card runs hot too often, you will hear the fan speed increase and decrease, or if things are really bad, the fan will run fast most all the time.
Here's a link to the ATI utilities:
http://old-macs.com/Utilities_Info/Ati_U...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks Mayer-
It all works fine after I went back up to San Jose and got the cable that should have been in the box to connect the card to the motherboard.
I can set the rez now as well.
Thanks for your interest.
paolo
댓글 달기
귀하의 답변을 추가하세요
Paolo Alberto 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,705
