주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
mower starts but will not engage in forward or reverse
My mower will not go forward or in reverse when moving the levers forward or backward. No symptons could be detected prior to the issue. I was mowing and starting to go in reverse and it would not go. At that time it would not go forward either.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 4개
broken drive belt
how do you replace it.
i had a broken belt spring at the back of my Z-726X that controls going forward and backwards. Easy fix.
I have the same problem, under seat i not sure where the tensioner spring hooks to? The frame to pully or some where else. Plz
댓글 달기
답변 1개
선택된 해법
I would replace the drive belt. Instructions will be in your manual. I attached an image of the instructions and the belt routing. The manual is available online at http://www.hammerwall.com/Download_Manua... little bit of an odd site, but it works :-)
이미지
Good Luck
이 답변이 도움이 되었나요?
점수 4
댓글 13개:
Checked belt, it's not broken, what else can it be
May Thigpen same mower? Same model? Same problem? what does it do? What have you checked?
my wife found a spring under the back of the mower when this happened to us. connection?
I am having the same problem the bottom pulley in the back does not turn the upper seems to turn, there was a ringing noise right before it started to act up. JH
Jesse Hubbart same mower same setup? What upper and lower pulley? The ones on the drive?
댓글 8개 더보기
댓글 달기
답변을 추가하세요
Danny 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 84
전체 시간: 103,948
