주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
1.6, 1.8, 또는 2 GHz G5 프로세서
172 질문 전체 보기
How do I fit the hard drive temperature sensor
I have been given the above model and upon looking inside I noticed that the temperature sensor was lose. I have had a quick look and cannot see where it is supposed to be attached.
It is attached to the Hard drive casing.
Can anyone help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 2개
선택된 해법
Remove the RAM and you will see the small black Receptacle that it plugs into.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
의견 추가하세요
Link to guide
Step 4, there you can see how the thermal sensor is placed.
Update:
I believe that the thermal sensor cable is connected to the underside of the logic board. See my comment for details.
I would remove the logic board from the case and look for a free connector on it's underside.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank you for your answer. However it is not the answer I am looking for. As you will see from my original question the cable is attached to the drive casing. I need to know how and where to attach it to the base unit not the hard drive case.
Sorry, I misunderstood your question. If you take a look at the logic board guide it looks like the cable is seated on the underside of the logic board. I would take it apart and look for a mounting point that isn't used. If the cable fit's it is probably the one. Apple dosen't usually have unused connectors on their logic boards.
의견 추가하세요
귀하의 답변을 추가하십시오
Adrian 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,823
