주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone doesn't charge after drop down
Hello everyone!
I dropped down my iPhone 6. The phone had only cracked screen, so I was happy with result because the phone still worked. But! Before I came home, the phone was out of battery, so I plugged it in to the charge but nothing happened after 24 hours in charge. DEAD.
I tried to change battery but still nothing.
When I tried to measure the battery after 24 hours in charge, it had 0V.
I tried to measure input voltage on motherboard and it had only 0.8V and I think that is a problem.
It looks like bad charging dock or something like that. What do you think?
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Thank you guys. I hope that will be the right solution.
댓글 달기
답변 2개
선택된 답변
Definitely the charging port.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If the lightning cable doesn't go in fully into the charging port then you'll need to clear it of debris inside the charging port. Something like a toothpick or equivalent will work for cleaning it out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I think that the problem will be inside charging port. I will buy new one.
댓글 달기
귀하의 답변을 추가하세요
Milan Rada 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 144
