메인 콘텐츠로 스킵하기
A one-hand dispensing 12-Cup programmable coffeemaker with an insulated tank and heater that was released on December 15, 2008 and produced by Hamilton Beach.
6 질문 전체 보기
Why does my coffee overflow the filter basket?
When I brew a normal pot of coffee, the filter basket overflows with coffee and spills all over the place. What am I doing to cause this to happen?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
Your problem could be from using too much coffee grounds, a bad filter and/or too many filters. If you use too much coffee grounds the coffee maker will not brew completely causing it to over flow. If you use a bad filter like a cheap brand filter this will cause an overflow. If you use too many filters the coffee ground won't brew almost anything causing it to overflow as well.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
not using too much coffee for water used. maybe you could give me deeper filters, been unable to find any.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Michael Damico 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 52
전체 시간: 1,394
