Does this sound like a logicboard issue?
I'm wondering if you guys can help.
Got a G4 1.33 that will not boot.
Straight to flashing folder. When I boot using install disk (10.4) it usually gets only as far as a blue screen and hangs. I did get it as far as the utilities and
it could not see a HD to repair. Also fsck cannot detect any HD, only the Tiger install disk.So far sounds like a new HD is in order but before I pull it apart one thing bothers me. When I'm trying to boot, it will sometimes freeze on the grey screen, just stop mid boot and in target mode, if I let that run long enough it will freeze and the FW will stay stuck in the same place.
I wondering if it more likely a LB problem, what do you think, worth changing the HD?
Guidance appreciated
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Possible ESD hit RAM problem or seating problem. Remove the RAM and try booting from the System 9 installation disk by holding down the "C" key. If it works then it's the RAM. Reinstall RAM and try again. If it fails, replace it.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Mayer, thanks for the reply. More questions I'm afraid. What is ESD? I have removed the additional 512mb stick and Airport card with same results. System 9 is OS 9 correct? That's on the Install disks that came with the Mac not the Tiger Upgrade, is that right?
의 답변
Electro Static Discharge
의 답변
Got it! Googled after I asked the question. Acronyms eh? PITA!!
의 답변
We're even, I had to google PITA ;-)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Neil Sinclair 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 600
