really loud banging noise, still dries
Dryer heats up fine it does sparatically shut itself off, and has a steady, rapid, very loud metal on metal banging.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
선택된 해법
Cause 1
Drive Belt
The drive belt is a very long, slender belt that wraps all the way around the dryer drum, around a tension pulley, and then around the drive motor. Over time, the drive belt can become frayed or otherwise damaged. If the drive belt is frayed or damaged, the dryer will be noisy as it turns. Inspect the drive belt for signs of wear. If the drive belt is worn, replace it.
Cause 2
Drum Roller
One or more of the drum rollers might be worn out. Many dryers have two drum support rollers on the rear of the drum, and some dryers have two more rollers supporting the front of the drum. When the drum rollers are worn out, they can cause the dryer to make a loud rumbling noise. To determine if the rollers are worn out, inspect the rollers. If one or more of the rollers are severely worn, we recommend replacing all of the rollers at the same time as a preventative measure. (The roller shaft can often be reused if it is in good condition. Clean the shaft thoroughly before installing the new rollers.)
Cause 3
Drum Roller Axle
One or more of the drum roller axles might be worn out. Most dryers have two drum support rollers on the rear of the drum, and some dryers have two more rollers supporting the front of the drum. Over time, the drum rollers and axles wear out, causing the dryer to make a loud rumbling noise. To determine if the drum roller axles are worn out, remove the belt from the dryer and try turning the drum by hand. If the drum does not rotate freely, check the support rollers for wear. If the rollers spin freely without wobbling, the axles do not need to be replaced. If a roller wobbles and/or does not spin freely, we recommend replacing all of the axles and rollers as a preventative measure.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
Watched YouTube video on how to disassemble the dryer. Found lower rear support roller broken. Went to local sears parts store and bought set of two new rollers. New rollers much thicker and stronger than the original factory rollers. The plastic part of the roller is what was broken. No more noise.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dave Howell 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 75
지난 30일: 423
전체 시간: 5,640
