주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
Rear camera doesn't work even after replacement
Hi everyone
I have iPhone 5 that the rear camera doesn't work.
I have restore the phone to factory settings and replaced the rear camera and still no luck.
The camera is just black. Front camera working.
I disconnect the battery and connect it again.
Any more suggestions please help
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
I have the same issue with an iPhone 5s.
Did you try to factory reset the phone with iTunes?
댓글 달기
답변 3개
선택된 해법
For example it's not the first time that I see this component u13 fail. If you can measure the rear camera tension on the line before this component but not after it you can remove it and run a jumper to restore the tension that allows the rear camera to work. It could also be one of the many filters or capacitors that are on the rear camera connector lines, they are a lot. It's not easy to find the problem and it's also more difficult to fix it without a microscope and some experience in microsoldering.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
thank you very much for the support.
you're welcome
댓글 달기
Take it to Apple ask them for a complete fresh install of iOS not just a restore
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Any other suggestions different than taking it to Apple?
댓글 달기
There are several component on the board that could have failed so there is not the right communication between the logic board and the rear camera. It is a microsoldering work, without the right equipment and skills you can't do anything more than that, I'm sorry. You could try another camera but it almost impossible that the two you have now are both faulty.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi James can you send me example of the components that may fail? Thank you
댓글 달기
답변을 추가하세요
Mimi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 209
