주요 콘텐츠로 건너뛰기
Laptops manufactured by Medion.
40 질문 전체 보기
질문 마감됨
Space bar come off
How to put space bar back on.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
The space bar is a little bit tricky to realign. Start by figuring out if there is a stabilizing wire in the space bar and where it is. You'll know because there is what looks like a really long paperclip that has been unfolded and bent differently, and attached to some clips, either on the spacebar key or in the main board. Remove this wire if it on the mainboard by bending it slightly. You want to bend this bar as little as possible to avoid irreversibly deforming it. Clip the stabilizing wire onto the space key using the small plastic clips on the key itself. Use a cotton swab to lubricate both ends of the wire ever so slightly. Remember, in this case, less is more, and it is VERY easy to over apply. Slide one end of the stabilizing wire into the loop on the mainboard, then bend the wire until it is on the other loop. Align the scissor switch in the center of the spacebar and press down firmly until you hear two or more clicks.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 136
