주요 콘텐츠로 건너뛰기
Released in September 2014, the Samsung NX1 is a smart camera that utilizes the unconventional mirrorless lens system.
11 질문 전체 보기
Why won't the battery door on my camera stay closed?
When I try to shut the battery hatch door, it won't stay closed and in place. Why does it keep opening?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
The battery may not match the Samsung NX1 camera. Read the battery label to make sure you have the appropriate battery type.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The battery may be inserted incorrectly. The battery does not need to be forced into place. The blue tab should slide into a groove that holds the battery in place on the negative-positive side of the battery. You must also push the battery all the way down, so that the spring is compressed, and the blue tab locks the battery into place.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hannah Patrick 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 972
