주요 콘텐츠로 건너뛰기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 질문 전체 보기
The repair kit didn't work..
I have purchased the xbox 360 rrod fix kit and installed everything but i still have the rrod..
Please help me..
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi Willemsesley,
If you haven't already, try using this guide to reflow the motherboard on your Xbox 360. It's even worthwhile to try this before installing the RROD Fix Kit. It's also worthwhile to check the new heat sinks and thermal pads to confirm that they're seated correctly.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Terminals 261- -300 solder joints under the GPU only have pulled away from the board and
will need to be reflowed at 260c and then clapped with a stronger ( more ridged bracket ) upgrade
the kits bracket is thin cheep , weak aluminum and is not sufficient to clamp the GPU with enough force
to get you reconnected , I'll see if I can find the supplier for the 1/8 " STEEL GPU clamp and post it here .
THE CONSOLE IS SALVAGEABLE < JUST DON"T USE A HEAT GUN ON THE BOARD until you get this clap.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
willemswesley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 194
