GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
183 질문 전체 보기
iPad 2 in a boot loop after a battery disconnect and reconnect
I replaced the back cover on iPad 2 and exchange all components to new cover including some being replaced new. When finished I power up to test all functions. I got a good boot and home screen but in less than 2 minutes in went into a boot loop with about 1 minute delay after boot before home screen appears then 1-2 minutes and boot loop and won't stop. Any suggestions?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Have you tried charging it for like an hour or more while turned off if possible?
의 답변
I was able to fix it, what I did was go back and remove the logic board disconnecting the battery clean the battery contacts with alcohol allowed to air dry and reassemble. it worked perfectly no more problems
의 답변
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
2개의 답변
선택된 해법
In my case I did actually fix my own problem, I disconnected the battery by removing the logic board cleaning the connectors with alcohol allowed to air dry and reassemble. It worked perfectly no more problems.
Thanks guys for your input have a great day !
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Hi Danny
Try to restore it to factory settings.
Hope this help
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Danny Hartley 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 171
