주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
573 질문 전체 보기
One of my USB Ports don't work. Tested power with USB Meter.
One of my USB ports don't work on my MacBook Pro. Tested the power with a USB Meter.
  • 1st port has power.
  • 2nd port has no power at all
Any device I plug in doesn't work on the 2nd port.
Is there anything I can do to fix this issue?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
There is a small fuse link just behind the USB port that you have burnt by plugging in an over powered device. Make sure you used the correct power unit for the device as well as make sure you use a surge suppressor for both your computer and the USB devices.
If you have access to a self powered USB hub and plug it into your bad port and then plug something in to the hub the device should work then.
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
귀하의 답변을 추가하십시오
Blanco 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 90
