주요 콘텐츠로 건너뛰기
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
368 질문 전체 보기
Replacement for rubber feet located at the upper back plate
Are there any website that sells rubber feet located at the upper back plate of the device? If not then is there any way to make it adhesive enough without using liquid-based adhesive like superglue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Hi @faux I got the easiest solution for you and here you go. http://www.amazon.com/Self-adhesive-Clea... I use these alot and even though they are clear they do the exact same thing and all you have to do is peel them off and stick them to whatever I use them on electronics, tool cases, Ifixit 64 bit kit and what ever I don't want to slide which is what those original feet did but they are just clear instead. I hope this helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
J Gab 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 658
