주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
262 질문 전체 보기
White screens flash and then powers off..
So I have an Nintendo dsi XL and I replaced the power board and from that time i have the 2 screens that flash white and then power off..
I already tried to reconnect all connectors, but that didn't help...
Any ideas ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
UPDATE 2.0
It was the Fuse un the power board that caused all that trouble. In fact it was a fuse with resistance! So it powered off when it was underpowered! I just removed the fuse and it worked (replaced with a wire)!
I hope this will help somebody with the same problem!
Louis
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
which fuse???
댓글 달기
가장 유용한 답변
OK I FIGURED SOMETHING OUT !!!!!
When I push SELECT and VOLUME DOWN on boot it works BUT when I power it off on MAX brightness it doesn't power on anymore !!!! SO if I put the brightness just one step DOWN it WORKS !!
Still I would like to know what's causing that problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Louis de Looze 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 107
