주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
779 질문 전체 보기
apple hardware test error code 4sns/1/C0000008 TPCD--124?
I have a Macbook Pro early 2011 model
The hardware test give me this error 4SNS/1/C0000008 TPCD--124
Can you tell me something about this error?
and if there is any solution you can help me it
thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
선택된 답변
the “4SNS” in the example above means there is a problem with a system sensor, which can be a temperature sensor, a current sensor, or a voltage sensor. Now you can determine which of these is the case by looking at the final detail of the reading (TPCD--124). In this case “T” stands for temperature, but it could also be “I” for current, or “V” for voltage.
The letter following the “T,” “I,” or “V,” lets you know what component of the system the sensor is in. The following list is a breakdown of what each of these components is:
A: Ambient air sensor
B: Battery
C: Central processors (CPU)
D: DC (direct current)
e: PCI-express slot
F: FireWire port
G: Graphics processor (GPU)
H: Hard disk
h: Heat pipe (heat sink)
L: LCD display
M: Memory or memory riser boards
m: Misc. (i.e., battery chargers)
N: North bridge (motherboard controller)
O: Optical drives
P: Power bus
p: Power supply
s: Palm rests for laptops
W: Airport Wi-Fi card
해당 답변은 도움이 되었습니까?
점수 8
댓글 1개:
hello. i have 4sns/1/C0000008: TPCD--124
is a Temperature problem and the second letter is P (power bus) any suggestions? thanks
댓글 달기
귀하의 답변을 추가하세요
djamel edw 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 6,434
