주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
The HP Pavilion w2216h is a widescreen 21.6-inch 1680x1050 LCD Monitor.
9 질문 전체 보기
Why does the image on the display look incorrect?
There is an image on screen but it doesn't fit the monitor. It also doesn't seem to be centered.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
The first thing you should do is ensure the computer is outputting an image that is the same size as the display. This can be done by right clicking on the desktop and selecting "Display Settings". From there select "advanced options" and set the resolution to what is recommended (This should be 1680x1050).
If that doesn't work try calibrating the monitor by pressing the menu button on the bottom left corner and using the "+", "-", and "Select" buttons to start the "auto" function. This should center and size the display on the device.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jessica Carreiro 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 46
