Can't reinstall OS X after SSD installed
Hello and thanks for the support,
I recently replaced my HDD with an SDD doubled my RAM and replaced the battery in my 2009 MacBook pro.
Installation went fine until I wanted to reinstall os x.
1. First my trackpad will not work in utility start up window.
2. I was making due with key commands and got to the reinstall OS X window after reformatting my new ssd in disk utility to Mac extended journaled. I would reach the screen were it says select disk to install osx and it wouldn't let me start the install on the new sdd even though it showed up.
3. I kept trying and now I am getting the blinking folder with a question mark or the circle with a line through and it won't even take me to utility.
4. I have both the original osx install disk and a USB stick with osx Bootable install for maverick. I also have the old hdd in a USB 3 case to use as an external.
And help or suggestions would be much appreciated! Thank you
좋은 질문 입니까?
댓글 1개
Is your trackpad not working at all? Are you able to plug in a USB or connect a Bluetooth mouse to your system for now?
Dan 의
