메인 콘텐츠로 스킵하기
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
191 질문 전체 보기
DSi does not turn on or charge
I bought a dsi off of eBay, and I had to replace the top screen. After reassembling the unit, I held the power button, and nothing happened. I plugged it into my charger, and the charge light won't even blink, just nothing. I checked the F1 fuses on the motherboard and the power board, and they are intact. I checked the connections for the ribbon cables to the top screen, and they seem OK, what is wrong???????? I will check the connections again, but I don't think that they are the problem.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
Looks like one of my two suggestions worked, which one was it so others know to check there too?
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
If you've plugged your charger into the port and you're not getting an indicator light on then it's gotta be 1 of 2 fuses (assuming you've checked with the multi-meter on continuity mode) OR your charge port has lifted from the motherboard. Double check the port on the board to see if it's all seated correctly.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
the charge port had lifted from the mb.
의 답변
Thanks for the follow up. Break out your soldering iron, flux and you can get that seated back to the board in no time.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
me I 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 72
