Problem with Gigabyte GTX 970 PC startup
Hi,
At the beginning everything was working fine, some time ago I've noticed that my PC have problems with start-up, it's not an issue related with power supply (I have three now...), RAM, processor, cooling nor motherboard, because from time to time it's working (I have no idea why), and the interesting thing is that I have other GTX - a 560 model, which works completely fine.
I sent back GTX 970 to the seller and they said it's working on their computer, so where is the problem? I've been thinking that maybe the BIOS is outdated, but I can't check it if my PC won't pass through BIOS to Windows (no "beep", monitor is black - actually it's not turning on with GTX 970 connected) everything else is working (fans - even 970's fans are rotating!) fine I guess. And also I've been disconnecting everything and start from the scratch - even trying to connect all items to my new motherboard (ASROCK) - nothing has changed.
Please HELP!
P.S.: Sorry for my bad english, I'm frustraited!
좋은 질문 입니까?
댓글 14개
Is it the GTX 970 Basic or the GTX 970 EVGA? Apparently the EVGA one is way better in performance. What Computer are you attempting to install it on, it might not be able to handle the new Video Card.
Brian Reeder 의
It is exactly this one:
http://www.gigabyte.com/products/product...
And it was working for over month completely normal, after that suddenly sotpped responding :)
hubertjadczak 의
Try your old Video Card if you still have it and if it doesn't work then it is most likely your motherboard.
Brian Reeder 의
But the problem occurs on both motherboards, I don't know what it depend on, I've checked everything, and GTX 970 is working from time to time (mostly not working).
hubertjadczak 의
Can you send it back to get your money back? I would if you could and get another one or a different one because that one might still be bad even though they said it tested good they could be lying.
Brian Reeder 의
댓글 9개 더보기
