주요 콘텐츠로 건너뛰기
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 질문 전체 보기
Samsung Galaxy Note 10.1 stuck in reboot cycle
plss fix this samsung galaxy note 10.1
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
why i cant fix
it was stuck in reboot cycle plss fix
댓글 달기
답변 2개
가장 유용한 답변
Have you tried pushing the power and volume up buttons together or the power and the volume down to power down the device? If it is off you could then either try to start it normally or try to flash a new ROM onto the device.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I would take out the battery and then put the battery back in, but if it is an internal battery like an apple product you might have to get the battery to turn off fully until it will not even turn on then charge it and turn it on and hope for the best.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
i try it but didnt work
You might have to reset to factory default to see if that fixes the reboot cycle.
댓글 달기
귀하의 답변을 추가하세요
Adam Matthew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 366
