2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
954 질문 전체 보기
Cooling fan in the process of dying?
My MacBook Pro has begun to make noises - kind of a rhythmic rattle. It can get pretty loud. Sounds like it is coming from the left rear side of the body, which should be about where the left cooling fan is located.
I'm fairly confident the fan is going, but I'm curious if there is any way to confirm it, and/or fix it short of pulling it out and putting a new one in. Any chance it's just some dust or dirt? Or should I just go ahead and try replacing the fan?
Thanks.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
I would open up the computer to try cleaning first and to check for a loose object touching the fan. If that does not cure it I would replace the fan. Use the ID guide to find the correct guide for your computer.
http://www.ifixit.com/Info/ID-your-Mac
해당 답변은 도움이 되었습니까?
점수 2
댓글:
의견 추가하세요
my dads macbook pro is having the same problem in the right fan, it sounds like a grinding / rattling noise
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dale Gardner 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 2,397
