주요 콘텐츠로 건너뛰기
모델 A1297 Unibody: 2009 상반기, 2009 중반기, 2010 중반기, 2011 상반기 & 2011 하반기
544 질문 전체 보기
guide for replacing LCD screen
I cannot find a guide for replacing the LCD screen on 17" unibody.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
It did help but the screw location on the 17" is not the same so I have two screws securing the LCD that are not accessible without more information.
댓글 달기
답변 2개
선택된 답변
This GUIDE for the 15" model should suit you fine. It's basically the same thing.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
댓글 달기
The screws for the 17-inch Macbook Pro Unibody are underneath the bottom two corners of the assembly, under the rubber "gasket" if you will. If you take your fingernail, you can peel back the rubber about an inch from the corner of the LCD (an inch towards where it would say "Macbook Pro" if the glass was still attached).
Trevor - [URL|http://www.CrackedMacScreen.com]
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
hey trevor, wanted to thank you for giving that bit of info, never would have guessed apple hid the LCD screws behind there.
If i saw this first i wold know where the screws... %%** lol
댓글 달기
귀하의 답변을 추가하세요
Martin Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,729
