주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
질문 마감됨
iPhone 6 searching for signal. Wifi and Bluetooth work.
So one day my iPhone 6 would not find a signal. This happened right after an iOS update. No water damage. No physical damage.
Wifi and bluetooth work and I can make calls and send iMessages/sms normally on AT&T WiFi calling. If I am on Wifi that doesn't support AT&T WiFi calling I can send iMessages and access the internet but can not send sms texts or make calls. Everything else works great.
Here's what I know so far:
Any software settings, resets, restores, etc. have no effect on the issue.
For a few weeks I could regain cellular signal by twisting the phone from the top and bottom and/or applying pressure near the top right/center of the device. This no longer has any effect.
I am considering opening the device to see if any cables/connectors have come loose.
What should I be looking for and where is it in the phone?
What parts should I consider replacing?
Any other advice/help?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Most likely, is that you want to do a cellular antenna replacement. This is the lower half of iphone below the motherboard where the speaker, microphone and lightning connector is. There is a small golden connector/cable that is the cellular one. It is a very cheap ebay replacement so if it doesn't work you won't be missing out. Plenty of videos of it on ifixit or youtube.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 371
