Help identify this component. From Dell Venue Pro 8
My screen broke on the Dell Venue Pro 8. Upon opening it this blue component had broken off the right side of the top of the PCB. (see picture)
I think this was broken off while I was taking the screen off so just a word of caution to anyone else opening one of these.
the board has
bellaire mainboard PCB rev 2.1 printed on it but I cannot find anything about it of use.
My guess might be that a 1 axis gyroscopic sensor of some sort as there are 2 of them orientated at right angles between one another.
Any thoughts?
Update (05/08/2016)
I can almost certainly confirm this component does not have to do with the orientation as I am still able to boot and it does rotate as expected.
Still I would like to find out where I can purchase this to re solder onto the board as this one has had it's solder points broken off when it snapped off the board.
좋은 질문 입니까?
댓글 2개
On the one that broke off is there and metal bits that you can see from the outside? (It may just be a spacer)
ETHREAL1 의
ETHREAL1 thanks for your comment. I do not see any metal on the broken piece except for where it was soldered to the board. hopefully you are right and it is just a spacer but you would think they could use a piece of foam or rubber for that.
George 의
