주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3937 질문 전체 보기
Ripped the home button cable, can I still fix it?
I took apart my phone and ripped the home button cable, but I didn't tear the cable, I detached it from the screen side. Now the home button does not work at all. I was wondering if there was an easy way to reattach it instead of having to buy a new part. I know the touch ID might not work, but I just want to regain the home button's abilities.
Just to be clear, the cable was not ripped in any way, as you can see by the pictures below it was separated near the home button.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글:
You're going to have to replace the home button. Fixing this is very tricky as it requires a some soldering skills I'm not sure if this is even possible with a soldering iron and a microscope. You might need one of those expensive flex repair machines.
의 답변
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
선택된 해법
I agree With Ben on this one you need to replace the home button which up till a few weeks ago was a death sentence for your phone but you can now replace the home button and not end up with error 53. you will lose the touch id function of the home button when you replace it but there is a fix for the errror that will come up when you update the phone after replacing the home button
https://support.apple.com/en-ca/HT205628
a help for replacing the home button
iPhone 5s Home Button Replacement
replacement part
iPhone 5s Home Button Assembly
Hope this helps
iPhone 5s Home Button Assembly 이미지
상품
$34.99
해당 답변은 도움이 되었습니까?
점수 1
댓글:
@jimfixer means after updating the iOS the touch id will be able to work again with replaced home button?
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Jack 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 54
지난 30일: 257
전체 시간: 14,767
