주요 콘텐츠로 건너뛰기
Repair information for standalone freezers.
192 질문 전체 보기
Why is my upright freezer leaking a "lot" of water from underneath?
My upright freezer is leaking a "lot" of water from the bottom! I don't think it is quite as cold as it usually is, but the food is still frozen. I hear a noise, but not sure if it is just a fan, or motor, or compressor. Don't think it sounds as it normally does. The water covered my entire garage floor...I can feel cool air coming out the vents on the inside, but the foggy stuff isn't circulating.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Cause 1
Clogged or Freezing Defrost Drain
During the freezer’s defrost cycle, the defrost water exits through the defrost drain. Sometimes, the defrost water can freeze over the drain. If the defrost drain is clogged with ice, the defrost water will overflow the drain and leak from the bottom of the freezer. To thaw the ice inside the defrost drain, use a turkey baster and hot water to flush the drain. If your defrost drain freezes regularly, consider installing a drain heater to melt the ice.
Where do you live an how cold is it in your garage?
해당 답변은 도움이 되었습니까?
점수 7
댓글 1개:
It is not in garage but in the basement, which is set at 68F. Ontario, Canada
댓글 달기
my door was lift open by mistake none it will not freeze all the can you please help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
my freezer leaks from underneath ive told my new landlord but he just says thats what happens its about 6 yrs old it never did that before
my freezer is leaking from bottom my new landlord says its ok thats what happens but it has never done that before its 6 years old
댓글 달기
귀하의 답변을 추가하세요
gracie1rda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 14
7일 전: 114
30일 전: 407
전체 시간: 51,370
