주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
Upper component cable not fits to logic board
Hi. First, sorry for my bad English.
I just disassembled my iPhone 5s and re-assembled.
Then I found volume up button is not working though I can't find any problem in its cable.
Volume down, volume control and power button which connected together in its cable works well, but only volume up button does not working.
Then I found that this cable isn't connected well to logic board so I tried to re-connect it but it didn't went as my expect.
It doesn't fits well and it is connected obliquely.
If I push the floated side of the connector to connect it, the connector comes out and I can't connect it well.
What would be the problem? Do I have to replace the entire cable?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
i don't get it , you mean you can't put the volume button flex cable in the right place so the volume up button can't work? did the volume button flex cable even got broken?
I mean flex cable isn't in the right place, and I'm not sure that volume up button isn't working because of it. Flex cable didn't broken
댓글 달기
답변 1개
선택된 답변
If I had to guess you've either damaged the cable or you've possibly damaged the socket connector on the logic board. The easiest thing to do, would be to try a different cable, to rule that out
This guide has most of what needs to be done, but not all of it. Guessing you don't need the guide too much?
iPhone 5s Volume Controls Replacement
Here's parts. In case you don't have an extra one laying around
iPhone 5s Audio Control and Power Button Cable
iPhone 5s Audio Control and Power Button Cable 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Well, that might be a problem but it's too wasteful to buying new cable. Actually we don't know the exact reason.
You can just change the volume in settings
댓글 달기
귀하의 답변을 추가하세요
Alfred Woo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 85
