주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 7인치 RCA 태블릿(모델 번호 RCT6773W22)의 수리 및 문제해결 안내서입니다.
Tablet won't turn on
Tablet will not turn on. When power button pressed, screen shows a darkly whiteish screen. Nothing happens. We have even pressed resetbutton a few times. Still nothung
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 39
댓글 14개
my RCA computer tablet just quit working it went off
의
Where can I send this to my tablet won't turn on and I've tried the volume and start butten
의
My tablet is not working push the volume button and the on and off button it never worked
의
mine cant still work, :(, I tried everythin
의
My tablet is in fastboot mode and I'm not sure how it ended up this way. I have followed all of the suggestions on what to do but nothing works
Also it doesn't seem to hold charge
Do these two issues have anything to do with the other? Thanks for any help!!! I'm very curious as to what the problem is
의
댓글 9개 더보기
댓글 달기
답변 9개
선택된 해법
Sandy, read through a few forums on RCA tablet won't turn on, most of them suggest, push the power and volume up button down at the same time for 10-20 seconds. Try this once or twice. If it does not turn on wait a few minutes and try holding down power and volume button again. They also state to try charging it through your computer, as some times the USB will some how kick start the charging again in case of faulty tablet charger. Check and read the links attached for more info. on how to power up your tablet.
Check the attached links,instruction and guides, Good luck.
http://www.tomsguide.com/forum/id-248283...
https://www.youtube.com/watch?v=K1zOqKR8...
https://www.youtube.com/watch?v=m_SGKMsN...
이 답변이 도움이 되었나요?
점수 22
댓글 19개:
my tablet still inst working i tryed everything
의
My tablet isn’t turning on and I’ve pressed down the power and volume up button at the same time and I even charged it. It isn’t turning on
의
My tablet is not coming on at all what should I do
의
Yeah mine did the same easy fix..... Throw the ##&&% away
의
댓글 14개 더보기
댓글 달기
There is a reset hole on back of tablet next to the SD card slot. Use a paperclip to reset ( you should feel a slight click) then hold power button and voila!!!
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Thanks!!!! Merci Beaucoup!
의
the clip didn't fit
의
Try using a SIM removal tool
의
댓글 달기
I don’t know what I did that caused it to come on because I tried several of the suggestions here…like pressing the on and sound at the same time and reset.. but when it came on I think I was pressing the reset and on at the same time. I was about to throw it away before I found these postings. Now I have to put the little screws back in it as I had torn it apart to see if something was loose or broken
이 답변이 도움이 되었나요?
점수 1
댓글 달기
My wife’s RCA tablet had been dropped and would not “turn on”. I placed it on a different charger to make sure the charger wasn’t defective and while charging, I heard a chime from the tablet so I then I felt it had to be something with the display. Upon opening the unit, I found that the ribbon cable that connects the primary board to the display had been pulled from its socket. The cable was secured with a piece of tape on the battery and when dropped, the weight of the battery pulled the ribbon cable from its socket. Reinserted cable and all is well.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How did you get it open?
의
댓글 달기
The model I have doesnt have the volume buttons on it, they are all on screen, so what do I do now
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Same here, but if you look on the back right below your on/off button, you will see a little tab that has 2 dots, one bigger than the other, that is your volume button. Thats where mine is, try and see if yours is there, too. Big dot is up, small is down. Hope this helps.
의
댓글 달기
Thankfully, i followed the instruction by holding down the power button and the volume button at the same time for the 10 -20 seconds. First attempt nothing but on the second attempt it came on and is working. Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Took back off after I mashed reset button and all. I go to pull charger out and it flashed. It doesn't it when I try pull it out??
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Can you unplug the battery and plug it back in?
의
댓글 달기
Hello, I have tried almost everything I could find on YouTube to get my RCA Viking Pro 10 to work, and at 1st it worked when I unplugged the battery and plugged it back in, but then after a week of leaving it alone it just stopped working completely, the blue light to indicate that the charger is turning on but it should be flashing off and on, and it isn’t doing that, could this be a battery issue?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi, I have the RCA Viking pro tablet and it stopped working/turning on about a week ago and the blue light that indicates it’s charging stopped coming on. I tried everything to get it to come on and nothing worked so I got frustrated and left it alone. Then tonight I noticed the blue light was on indicating it was charging and I opened it and it was on but stuck on the Viking Pro screen like it was in a reboot loop or something, so I hit the reset button and it turned off and back on did the same thing for about ten minutes. So I hit the reset again and this time it’s back to not turning on and the charging light won’t come on again! Someone please help! It’s driving me insane! Is it a bad battery or what?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sandymf64 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 45
전체 시간: 71,452
