주요 콘텐츠로 건너뛰기
Released in August 2014, the Lenovo Y50-70 Touch is part of the Lenovo's Y series of laptops. Equipped with a dedicated graphics card and a 15.6" touch screen, the Y50-70 Touch is specialized for gaming.
36 질문 전체 보기
Why won't my laptop turn on?
Just yesterday i was using my laptop. When I went to go get something from my kitchen and came back, I found my laptop turned off. I don't know why it turned off. I wasent playing games at the moment. When I click on the power button, the lights turns on the power light, but I don't the fans or anything its just a black screen
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
two questions:
  • how long have you had the laptop?
* was the laptop plugged into the wall or running on battery?
I got couple ideas and similar experiences..
Lenovo hardware known for Power management settings
1- have you installed any new software or firmwares recently? and in addition to hdd change, how do you manage your power settings? I also have a lenovo (x1) and I found my computer doing the same thing (although mine does turn on when I forced shut it for like 10 seconds). turns out Lenovo is collecting complaints from customers who have trouble cycling their computers back on from sleep or hibernation because of hardware/firmware conflicts.
if your comp does turn back on, then change your power settings as closely as you can to their default options and watch for the weight of graphic processing. After I removed my custom "what happens when you shut the lid,etc" settings, I don't run into this problem anymore.
Rule out dead battery
2- have you noticed anything lagging about your battery life? ideally users should be able to observe diminishing capacity with usage duration and intensity. but maybe yours battery was on the its way and then experienced some shortage? remove the bottom panel and the battery (using proper methods) - uneven or misbalanced psu can damange rest of the computer with surges and what have you.
Power surge from your wall outlet?
3- one thing I've been experiencing first hand is the annoying power of faulty building wiring to destroy my batteries. if you had it plugged in , then one possible issue might be the constant ESD that accumulated to this moment. you see the slight sparking whenever you use the wall plug? if so you should look into a cheap voltage regulator (especially if you have long sessions under something as taxing as gaming).
let me know what happens, good luck!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Less than 1 year. And I had it connected to the wall.
댓글 달기
귀하의 답변을 추가하세요
Angel Galvan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 1,338
