주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3787 질문 전체 보기
Display doesn't work after optical drive replacement. Any ideas?
Hey there,
after changing the optical drive for my old macbook core 2 duo, i booted but the screen shows only black. the macbook seems to boot normally, i can control it with the keyboard (switch off and some easy key combinations).
with the dimmer on f2 i can lighten up the black a bit, so there's a difference in the screen compared to when the macbook is switched off.
is it possible that i've damaged the screen cable? a inverter problem, maybe the RAM? or the logic board? (i hope not ;) )
at the moment i unfortunately don't have the opportunity to connect an external screen would that be helpfull?
I would be glad if someone can help me!!
all the best,
stephan
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
an external display is working with no problems, i've resetted the p ram and ram
댓글 달기
답변 2개
선택된 답변
Recheck your cables--you may have loosened the cables to the LCD when you were changing the optical drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
+ My thoughts exactly.
+ agreed but hook up to that external monitor ASAP
thx i'll check it!
댓글 달기
thx a lot, i've loosened the display cable, you were right!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
stephan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 625
