주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
Repair guides and support for the ZTE n817, also known as the ZTE Quest.
67 질문 전체 보기
Where sim card. goes
Where does sim card go
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 10
댓글:
I have this problem too. The phone keeps telling me to mount an SD Card. And... I have no clue what that means or how to do it!
You can add a MicroSD card up to 32Gb to the phone. Put it in the slot above the battery inside the back cover.
i need to find the sim card in this phone any help i can get will work thanks!
How do I insert y sim card into my zte n817
I was wondering if you could put an SD card from a smaller Trac phone to a slight bigger Trac phone?
5에 댓글 더 나타내기
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 7개
가장 유용한 답변
No Sim card on cdma phone...n817 is a cdma phone
해당 답변은 도움이 되었습니까?
점수 5
댓글:
They didn't ask about a sim card. they asked about an sd card which is memory.
Yes,the answer was helpful in getting a good morning laugh aahhhhaha ha oohhhhaha dang! That was goodthat whole conversation was short,polite and hilarious ...Thanks
Thanks, this answer was very helpful.
This answer is incorrect. Some versions of the N817 use GSM, while others do not, including Lifeline phones.
@jmredingtx You are incorrect. The OP, Daniel, asked about SIM cards, not SD cards. You responded to a different person, timday365, who added a question about SD cards. Most others also asked about SIM card, but a year after your response, Maria Swope also asked about SD cards, but it was a different question - it was about migrating.
의견 추가하세요
There are 2 types of cellphone technology: CDMA and GSM.
GSM uses a SIM card on phone carriers like AT&T, T-Mobile, Rogers, etc.
CDMA cannot take SIM cards and relies on an ESN number inside the phone. Carriers such as Sprint, Verizon, Boost Mobile, etc. use CDMA.
You cannot switch between GSM and CDMA carriers on this phone.
Here is the manual for the phone.
https://zte-iqorsupport.custhelp.com/ci/...
IF it is a CDMA, there is no SIM slot.
If it is a UTMS/GSM/LTE, the SIM slot is above the battery.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
@oldturkey03 I don't get it... What's wrong with this answer?
@pccheese those are the right facts. Ask yourself this, does it answer the original question "Where does sim card go?" The answer given by "Alex cruz" is specific. Now if you do some research on the device and you see that it is listed as having a Sim card slot. http://www.imei.info/phonedatabase/91927...
Sorry I'm waiting at the DMV taking forever, a lot of time I have ATM lol
의견 추가하세요
The Sim-card is located inside the ZTEN817
Turn your device off prior to opening (from the bottom), once open one can then insert the sim card in the slot provided just above the battery.
To install one must first remove the battery.
That's it!
해당 답변은 도움이 되었습니까?
점수 3
댓글:
thats for an SD card moron, not a sim....sheeeesh
Hey Malfunction Junction, I guess you malfunctioned, because the OP asked about SIM cards, not SD cards...Which only some versions of the N817 have.
의견 추가하세요
Underneath the battery. ZTE confirm use of sim card in this phone.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Only some versions of the N817 can use a SIM card.
의견 추가하세요
This phone does not take SIM cards.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
If you are referring to Lifeline phones (free phones), that is true, but other versions of the N817 take SIM cards. It's listed in the specs.
의견 추가하세요
This phone don't have this.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Some versions of the N817 have it, but Lifeline versions don't.
의견 추가하세요
I’ll try again. Please read S W’s answer, as it was the correct one. Alex Cruz's answer is incorrect - GSM is shown in the normal specs for the N817 - but the Lifeline version does NOT have GSM as the government doesn’t want people putting a SIM into a free phone to effectively steal it.
If you follow Jo Anne’s instructions and find a SIM card slot, you have the regular N817. If you don’t, you have the other version, used for Lifeline phones. If you research it, you’ll find out it’s true.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Daniel szasz 9329 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 31
30일 전: 158
전체 시간: 36,389
