주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Charging port not getting recognized.
So my iPhone 5c is not recognizing when I plug it in. I thought it was it a bad charging port, so I replaced it. That didn't do anything. The headphone jack works and so do the loud speakers. I then took out the motherboard and put it in a full functioning iPhone 5c which I tested (charging port worked as well) but this motherboard failed to recognize when it was plugged in and wouldn't charge. The phone worked perfect from the remaining battery power it had, but since the phone couldn't charge. It died on me and I either have to put a new battery in it, or switch the motherboard back so it can recognize when it's connected and charge the battery that way.. I'm pretty sure this has to do with the motherboard, but I'm not for sure. Any recommendations?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
To clarify, your replacement charge port is not working with either motherboard?
No, the charging port works with one, but not the other.
댓글 달기
답변 3개
선택된 답변
Did you happen to try different cables . It may have been a cable problem not a phone problem
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Is sounds like it is the motherboard header for the power board... Look to see that there is no dust or something in it or that none of the pins are broken...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Okay thanks, I'll give it a try. I'm just confused because the headphone jack, speaker, and home button connection all work. Which is the same piece as the charging port.
댓글 달기
JIMFIXER I agree very well could be the charger itself. Double check with a second charging cable , I've seen things like this before, Sometimes it's just a phone being picky to the part. i would order another charge port from another vendor and see if this one works .. But also check the pins on the board to see if they are bent or anything like dust is in there on the one that is not working.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Pace Satterthwaite 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 137
