주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Backlight works but no images on lcd after install.
So I received my "high quality" screen from ifixit and installed it super smooth as 50 times before and it worked for about a day then customer asked why 3 buttons on the screen didn't work then apparently the phone powered off and all I could get on that screen was the backlight and 2 purple lines about a fourth in on the right side. So of course I went to slap another screen on and even tried oem but all I get is a backlight. Have tried home and power and disconnect battery and plugging it up with no success. HELP!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
this problem looks like you either burn the video chip out or maybe on the connectors they may be something that is not letting the lcd cables to direct connect with board
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Seems like the backlight chip is messed up. Can you try flashing a light on the screen and seeing if you see anything on it really dim or not.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
loganperkins42 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 82
