MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
4113 질문 전체 보기
Headphone jack only able to hear one side
I used to be able to plug the headphones into the jack and wiggle it around to get both sides to work. But now it is almost impossible to get it to work. So I can only hear one side when I plug my headphones in. Do I need to replace the Logic Board (is that what its called???) or is it something simpler than that?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Does this happen with all earphones?
의 답변
Yes, it does. Also with speakers. I can only get one side to work. Everything is mono...
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
Gabe, I think it is just like anything else. You get out what you put in, yes the USB cards are good to listen etc. but as for recording it depends how sophisticated you need and if you are looking at M-audio then I think you want sophisticated :)
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
The headphones jack is dead... and its soldered to the logic board so unless you're really good with soldering then you're gonna need to buy a new logic board...
An alternative is a USB sound card
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Hey Gabe,
Is a USB sound card pretty much just a cheap interface? If I'm interested in recording, would I be better off just buying an M-Audio interface or something like that?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Joel 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 3,303
