주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
3009 질문 전체 보기
Screen doesn't work a couple of days after repair
Hi guys,
I repaired my iPhone 4S screen last Monday, using iFixit tools and parts. The repair went perfectly, following the instructions here. The phone worked perfectly after the repair as well. Now today, out of the blue, the screen only showed a blurry grey, or, depending on where I applied pressure, displayed the screen as it should be. Everything else worked, messages, mails etc. were received, the phone vibrated, the touch screen worked. So I figured it was maybe a cable on the logic board that I failed to put in correctly, so I opened the phone again and checked all the connections. Upon turning the phone on again, the screen is now only black, and no pressure will display anything else than the 'light black' of an illuminated screen.
Did anyone already encounter such a problem? Is it possible that I broke something during my repair that only just now showed?
I guess my next step would be to just do it all over again...
I'm very grateful for every comment!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Hi,
It's possible you may have received a faulty part, message ifixit and they will probably replace it, providing you haven't actually damaged the part. :-)
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Hevin Karakurt 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 62
