주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
Huawei Ascend G510 Android smartphone. Announced 2013.
12 질문 전체 보기
Why is my phone screen black after it got wet?
Im sorry for my bed English. My phone got wet after dropping it in toilet. Took apart and wipe it then i but it back and my screen just went crazy, there was purple lines and black screen , so i again took it apart and after i put it back it didnt work, and it looked like there was moisture on screen so i took my hairdryer and dry it, still didnt work.That was a month ago, now when i turn on i hear a sound that mt phone its switch on but its black screen.Can i do anything to fix it?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 3개
가장 유용한 답변
it sounds like you definitely blew the LCD. but the fact that you took out a hairdryer could have done a lot more damage.
Replacing the screen may help, but with water damage the problems it can cause can be endless. you can take the risk if you like, but there is no guarantee it will work.
Most reputable repair shops that specialize in micro soldering would be able to help you, but the price of repairing it may be more than the phone is worth. It's up to you if you want to spend that amount of money.
If there is data on the phone that you need recovered though then they should be able to help you out with that too
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Thank you for you answer!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
esto sucede porque el conector de la pantalla perdio pistas por eso da pantalla oscura o pantalla
blanca
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Marla Durden 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,250
