주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
How to see a motherboard problem
Hi
I've just changed my battery in my iphone 5 but after that, the new battery unload really fast.
So then l return to the place where l bought it and the saler said me it is a problem with the motherboard.
But now l would like to know how to recognise a motherboard because l feel like the saler didn't put a new battery but one that have been already used...
Thank you
Eric
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
it definitely sounds like a problem on the motherboard with a chip called Tristar or U2. The problem is that this chip is draining more power than what you can put into your phone. Therefore replacing the battery doesn't address the issue at hand.
This is definitely a replaceable part, and is a very common problem. go to a repair shop that does micro soldering and they should be able to help you out.
If you want to give it a go yourself ill point you in the right direction on what to do, but it requires a lot of expensive equipment and even more time learning how to do it.
So I wouldn't recommend doing it if you haven't done it before.
A motherboard is basically a PCB/Circuit board that is inside your phone with thousands of microscopic sized components soldered to it. There is no way to see a motherboard problem, only ways to diagnose a motherboard problem. Kinda the same way that you can't see DNA but you can diagnose problems with it.
My biggest issue is why the repair shop you first went to didn't see the problem in the first place (As it only takes 60 seconds to test for) and refer you else where. We get customers coming in all the time asking for battery replacements and only about 15% actually need them, the rest have the U2 Problem mentioned above.
I hope that answers all your questions.
Melanie
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hi. I have the same issue. My phone also feels like it heats up. Also, if I press the power button and leave it on the table for about 3 minutes 30 seconds, it shuts down completely (and needs to be restarted). Could you guide me in the right direction because hte store I went to replaced the battery and couldn't fix the issue either? (iphone 5s in my case)
댓글 달기
Hey mate can you help me when i do record in the front camera and when i done then i review and the result is low sound i can’t really hear clearly the sounds not like in the rear camera just normal my problem is its just the front HD camera when i record please tell me if you know what is the issue
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Without more details like the model of phone you have, the only thing I can suggest is try cleaning the microphone ports on your phone
댓글 달기
귀하의 답변을 추가하세요
ericbuya 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 6,995
