주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Rear Camera Replacement - People Have Problems With Phone Afterward?
Hi,
I need to replace my rear facing camera in my Samsung S5. However, I noticed that a lot of people complain about things like:
- I broke a cable
- My __________doesn't work anymore
- I tore the foil
- etc.
So, this weekend, I'm going to do a camera replacement. I have all the tools, correct parts, replacement adhesive, and a clean place to do it with as much time as I need.
Do I have anything to worry about? I've previewed several tutorials, including the one at iFixit, and am just a little trepidatious.
Thanks in advance,
Maitai
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
iBar,
First, thanks for your answer earlier. This is an update.
I bricked my phone. The touchscreen did not work. The DISPLAY worked beautifully, but then touch did not, nor could I get the phone to start in recovery mode.
This job was necessary. I had to do it. I'm a firefighter as well as a Buildings Manager, and I can't live without a reliable camera on my phone.
I had EVERY single tool I needed - and then some. I even made my own iOpener (sock with rice, and all tied up - use water in the microwave in a cup, but then place plastic over the device while warming so as not to pump moisture into it.) For whatever reason, it just didn't work out.
Realizing I was in a tough spot, and that it would likely not be resolved by a tech (and after many attempts at fixing it myself through various means, found on YouTube,) I decided to pull the screen off again - and not lightly - I basically manhandled it off, because I just HAD to know whether or not the connector to the screen was properly seated. It was. So, whatever happened, probably happened when I was handling the board, or prying out the midframe.
I was going to go to Verizon to pick up something cheap, but then decided to switch to T-Mobile since they bought out the contract - I may be moving to a remote area, and T-Mobile is known to be excellent in the area I might go to, if I do. Looks promising, actually. Job change.
So, this was somewhat lemons into lemonade. Yeah, I'm on the hook for the 1/4 of the phone I bricked, but that's probably only about $125. I would've spent almost that on a replacement phone anyway for a crappy one to get me through the next 6 months, and if I do move, with crappy cell service. So I picked up an S7 at TM. It cost me $7.00 out the door.
All in all, I am very glad I did the repair; somewhat sad everything didn't work - proud of the fact it at least started back up, received messages and operated like it should - it's just that touch screen...
I did lift up a little of the foil on the back of the display the first time around, but it seems to me it was already pre-cut. I will say this, though, I had magnification and lighting (head unit) and went VERY slowly on cutting the old adhesive. I do believe I got the screen off properly, and through the other parts otherwise.
What went wrong with the touch screen?
Many, many thanks, iBar. You have no idea how much I appreciate all of what you did for me.
Regards,
Maitai
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
the screen is very fragile, you have to start on top, watch out for the touch cable and use enough heat to separate the lcd from the frame...
I wish you good luck but if you are not used to repair samsung phones the chance of failing is over 50%...
please keep us posted on how you did...
have a nice repair
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi iBar,
Many, many thanks for taking the time to help me in my endeavor. I appreciate your time and expertise - AND honesty with your opinion on success rates. No need to give pie-in-the-sky projections about what people think they can accomplish when it's unlikely to be true.
While I have not done this phone specifically, I have extensive experience with overhauling vintage mechanical pocket watches - which gives me the soft touch I hope will help me see this through. When you're dealing with the difficulty of trying to install a part that can only be seen with magnification and lighting, and at the same time, have to fight against your own tremors, breathing, and heartbeat to get the job done, I would hope a phone would be something I could do.
I'll update you when I complete the job.
Thanks again, you made my day.
Regards,
Maitai
댓글 달기
귀하의 답변을 추가하세요
maitaioneone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 97
