주요 콘텐츠로 건너뛰기
Complete disassembly and replacement guides for the Alldaymall A88X 7-inch 8 GB Android Tablet. Repair requires screwdrivers, tweezers, a soldering iron, and prying tools.
11 질문 전체 보기
Why is my tablet not letting me enable my wifi?
I have a 7 inch android tablet. I tried factory resetting it, but it won't work. Can you help me?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Can somebody please help me, I don't know what to do, and I cannot go on the internet or do anything anymore.
의 답변
is the wifi switch greyed out?
의 답변
Yes the wifi switch is grayed out even when I switch the wifi to on.
의 답변
의견 추가하세요
안드로이드 수리 키트
새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
지금 장보기
안드로이드 수리 키트
지금 장보기
1개의 답변
try enabling dfu mode on the ipad, this is done by turning it off, then hold the power button down for 3 seconds, then hold down the home button for ten seconds at the same time as the power button, then release the power button but keep the home button pressed for 5 more seconds, the screen should be black. what dfu mode is is device firmware update mode. once you do this you can turn your ipad on with as you would if it was off
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Bella Toskovic 가/이 대단히 고마워 할 것입니다.
조회 통계:
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
전체 시간: 199
