2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4638 질문 전체 보기
Why getting white screen when open any app?
when i open any application , even settings or contacts getting white screen and freeze. i tried restore OS but same, and tried replaced touch screen assembly still same.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
I can't open my emails either!!
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
5개의 답변
가장 유용한 답변
Bum bum bum fat bum willy big willy bum and willy big bum
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Does it freeze all the time you have your phone on and it shows a white screen or does it happen sometimes.
If it happens sometimes and the phone is somewhat functional try these's steps down below.
1 - The first thing is to make sure that your iOS device is connected to the Internet.
2 - Restart your device. To do this, press and hold the on/off (sleep/wake) button until you see the slider. Then slide the slider. Wait a few seconds then, to turn your device on, press and hold the on/off button until you see the Apple logo.
3 - Try this fix: Launch Settings then tap iTunes & App Store, Apple ID and Sign Out. Now launch the App Store. Tap Sign In, and enter your Apple ID and password.
4 - Tap Settings > General > Date & Time and and turn ‘Set Automatically’ on.
5 - Go to Settings > General > Date & Time and turn “Set Automatically’ off. Now set your date one year ahead, like 2017. Now go to the App Store. If your issues is fixed, turn on ‘Set Automatically’.
6 - Go to Settings > Privacy > Location Services > System Services > and make sure that Location-Based iAds is tuned off.
7- Go to Settings > General > Language & Region. Change the current language. You may select any language. However, you may want to choose a language you know. Then open the App Store, if your apps load, then go back to the Language settings, and change your language back.
8 - Update the iOS software. Simply go to Settings > General > Software Update.
9 - Restart the all your apps running in the background. Double press the home button and swipe up on the apps running, preview to close it. Then reopen an app to see if you still get the white screen or freezing.
I hope this helps you.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Yea even while playing with apps such as Showbox, kodi, Tutuapp or any such app facing the same issue this side on my iPhone 7+.
With Regards,
Protar [https://plex.software/|https://plex.software/]
https://tutuappx.com/
https://vidmate.onl/
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Basic thing you can do is , restart your iOS device. I also faced that problem when i open my appcake app.
I have restarted and it doesn’t work . After that i remove appcake from my device and installed it again with this tutorial. Then it works well.
http://freecydiadownload.com/install-app...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Yes I have that same problem too
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
shuhaibvc 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 54
지난 30일: 321
전체 시간: 16,656
